A1707 820-00281 won't wake from sleep with high fan spin
Soji
SMC_LID_LEFT_R=3.4v
HALL_SENSOR_LEFT=3.4v
SMC_LID_LEFT=3.4v
SMC_LID_RIGHT=0V
SMC_LID=3.3V
I checked SMC_LID_RIGHT at R5253..
Then i jumped a wire from pin 1 of R5258 to pin 2 of R5253..
now system is not coming up...
Board should wotk now, with the jumper you did before.
If you change J5260, then solder back R5253 and remove the jumper.
Soji
I have solder R5253 and changed J5260...
System now boots fine and waking up from sleep..
But one of the fan spins high..
Soji
Fan now spins normal after replacing it..
But system is not coming up with charger only..
It just displays charging sign and goes off..
