A1707 / 820-00928-A Won't boot
try connecting only the battery, display and USB port and check if it will start? (without the power button, trackpad and keyboard)
ok I'm stupid, I'm getting 5.187 volts .084 amp with battery and display only plugged in. I "assumed" J8500 was the display, the display is J4401. Sorry
"If I try my volt meter on the new battery I get 0v? The old battery is at about 2.2 volts?"
Did you check on battery direclty, without connecting data cable?
Data cable enables the battery...
Yeah I just read directly off the battery connector. I was just curious if they had any charge.
Without enabling the battery???
Irrelevant measurment; battery must be connected to MLB, with its data cable too.
"the display is J4401"
NO, it is J8500.
Work with the board alone on the desk, using known 87W charger.
Just in case, try SMC bypass also.
Will not charge the battery in such case, but let see if turns on at least.
Please, stop to quote entire messages, visible few centimeters above.
NO, it is J8500.
Sorry I'm confused do you want me to reply so that it shows the question I'm replying to like this one, or just reply without it?
Glad to work the board alone on the desk, I'm not sure how to do a SMC bypass but willing to try anything.
thanks
I would assume you prefer that I don't reply with the previous question to keep things shorter? When you say SMC Bypass if you mean the SMC Reset, then yes I've tried that before trying to get it to boot. I didn't try to do that and take any readings, but I would be glad to.
No need to quote an entire post, above visible.
Write directly into bottom reply box, instead of clicking Reply button.
SMC reset and bypass is not the same thing...
Cool, so I searched for ONOFF and see the SW5200 and looks like I can just short 1&2 or 3&4 and that will simulate the power button.
So board alone on the desk, I assume you want me to plug in the USB-C charger and do the SMC bypass, what do you want me to check after that?
Maybe PPVBAT_G3H_CONN at like C7060 pin 1 to see if the charger turns on?
I put the board back in and plugged everything in. Now the left side USB-C ports only show 5.195 volts and 0 amps. If I try the right side USB-C ports it shows 19.87 volts and 0 amps? either way I try SMC bypass and nothing changes.
Yeah I checked F3001 and getting 5.17 volts there, but at C3208:1 getting nothing now. I've checked these damn things at least 4 times and they have all worked but not now.
Checking U3100 I get 5v on F3000, 3.376 on C3108, 1.796 on C3105, 1.802 on C3106 but 0 on C3104 and U3100 feels warm.
Checking UB300 5.19 on FB200, 3.376 on CB308, 1.791 on CB305, 1.796 on CB306, 1.112 on CB304 but only 10.91 on QB300:1 and 7.5 on QB300:4
Checking UB400 same as UB300
