A1707 820-00928 Sometimes kernel panic in sleep mode. Seems to be hardware
Beeldbuisje
Laptop works perfect, never crashes, but sometimes when going into sleep modus, this thing reboots and tells about Kernel Panic. It happens both on charger as on battery, but more often when connected on charger.
Read some stories about defective Touchbar, but this Touchbar works fine.
This Macbook has a "new" board with original fault a short on C4928 (PP3V0_MESA_CONN).
So after the change, I had a few crazy things on the touchbar when waking from sleep (not responding, some vanished symbols,...). Reset PRAM solved it, but after doing this, I sometimes get this Kernel Panic.
What could this be?
panic(cpu 0 caller 0xffffff7f97a1346b): "Failed to quiesce supporting devices in last sleep attempt (0x9) after sleep/wake(2/1), M8 was available, sleepFailCnt(0x100), Healed(1), Panic(1), SMC(0)" @AppleEmbeddedOSSupportHost.cpp:983
Panicked task 0xffffff9075e89670: 223 threads: pid 0: kernel_task
Backtrace (CPU 0), panicked thread: 0xffffff8ba9621540, Frame : Return Address
0xffffffe590dd37a0 : 0xffffff8000281c8d
0xffffffe590dd37f0 : 0xffffff80003e1596
0xffffffe590dd3830 : 0xffffff80003d0963
0xffffffe590dd3880 : 0xffffff8000221a70
0xffffffe590dd38a0 : 0xffffff800028205d
0xffffffe590dd39c0 : 0xffffff8000281816
0xffffffe590dd3a20 : 0xffffff8000b15163
0xffffffe590dd3b10 : 0xffffff7f97a1346b
0xffffffe590dd3bb0 : 0xffffff8000a43b4e
0xffffffe590dd3bf0 : 0xffffff7f97a12043
0xffffffe590dd3c30 : 0xffffff8000a127a9
0xffffffe590dd3ca0 : 0xffffff8000a2ea9d
0xffffffe590dd3d50 : 0xffffff8000a12fd9
0xffffffe590dd3da0 : 0xffffff8000a2bae5
0xffffffe590dd3e40 : 0xffffff8000a27afb
0xffffffe590dd3e90 : 0xffffff8000a255a0
0xffffffe590dd3ee0 : 0xffffff8000a2543a
0xffffffe590dd3f20 : 0xffffff8000a43cae
0xffffffe590dd3f60 : 0xffffff8000a432d7
0xffffffe590dd3fa0 : 0xffffff800022119e
Kernel Extensions in backtrace:
com.apple.driver.AppleEmbeddedOSSupportHost(1.0)[81F3441D-FB76-37F9-AF16-074F714792D5]@0xffffff7f97a10000->0xffffff7f97a14fff
dependency: com.apple.driver.AppleSMC(3.1.9)[2B59F3D8-402A-351E-AF4E-6F42A7923DBB]@0xffffff8001a5f000->0xffffff8001a77fff
dependency: com.apple.iokit.IOACPIFamily(1.4)[3224D91D-C81D-33E2-A8B3-1A168235F4E7]@0xffffff800297b000->0xffffff800297cfff
Process name corresponding to current thread (0xffffff8ba9621540): kernel_task
Mac OS version:
21F79
Kernel version:
Darwin Kernel Version 21.5.0: Tue Apr 26 21:08:22 PDT 2022; root:xnu-8020.121.3~4/RELEASE_X86_64
Kernel UUID: 3C587984-4004-3C76-8ADF-997822977184
KernelCache slide: 0x0000000000000000
KernelCache base: 0xffffff8000200000
Kernel slide: 0x0000000000010000
Kernel text base: 0xffffff8000210000
__HIB text base: 0xffffff8000100000
System model name: MacBookPro14,3 (Mac-551B86E5744E2388)
System shutdown begun: YES
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 2457451862939
Last Sleep: absolute base_tsc base_nano
Uptime : 0x0000023c2b8b9ea0
Sleep : 0x0000023bdefee626 0x0000000081b9e880 0x000002259b7e9906
Wake : 0x0000023be96725d3 0x00000000817e766a 0x0000023be77c9eb7
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff8074ef4000 - 0xffffffa074ef4000
. PGZ : 0xffffff8074ef4000 - 0xffffff8076ef5000
. VM : 0xffffff8076ef5000 - 0xffffff85436f4000
. RO : 0xffffff85436f4000 - 0xffffff86dcef4000
. GEN0 : 0xffffff86dcef4000 - 0xffffff8ba96f4000
. GEN1 : 0xffffff8ba96f4000 - 0xffffff9075ef4000
. GEN2 : 0xffffff9075ef4000 - 0xffffff95426f4000
. GEN3 : 0xffffff95426f4000 - 0xffffff9a0eef4000
. DATA : 0xffffff9a0eef4000 - 0xffffffa074ef4000
Metadata: 0xffffffa074f04000 - 0xffffffa094f04000
Bitmaps : 0xffffffa094f04000 - 0xffffffa09af04000
last started kext at 2230223973158: >usb.cdc.acm 5.0.0 (addr 0xffffff7f9901d000, size 12288)
last stopped kext at 2214580672108: >!UAudio 416.2 (addr 0xffffff7f99023000, size 335872)
loaded kexts:
@UVCService 1
@filesystems.smbfs 4.0
>AudioAUUC 1.70
>!AHIDALSService 1
>X86PlatformShim 1.0.0
>!APlatformEnabler 2.7.0d0
>AGPM 129
@kext.AMDFramebuffer 4.0.8
@filesystems.autofs 3.0
>!AHDA 340.2
@kext.AMDRadeonX4000 4.0.8
@kext.AMDRadeonServiceManager 4.0.8
>!AUpstreamUserClient 3.6.9
>!AGFXHDA 140.3
>!AGraphicsDevicePolicy 6.5.7
>!A!IPCHPMC 2.0.1
>!AMuxControl 6.5.7
@AGDCPluginDisplayMetrics 6.5.7
@kext.AMD9500!C 4.0.8
>pmtelemetry 1
|IOUserEthernet 1.0.1
>usb.!UUserHCI 1
>!AHV 1
>!ADiskImages2 126.100.13
>AGDCBacklightControl 6.5.7
>!A!IKBLGraphics 18.0.7
>eficheck 1
>!A!IKBLGraphicsFramebuffer 18.0.7
>SMCMotionSensor 3.0.4d1
>!AEmbeddedOSSupportHost 1
>!AMCCSControl 1.16
>!AThunderboltIP 4.0.3
>!A!ISlowAdaptiveClocking 4.0.0
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.lifs 1
@filesystems.hfs.kext 583.100.10
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
>!ATopCaseHIDEventDriver 5450.8
@filesystems.apfs 1934.121.2
>AirPort.BrcmNIC 1400.1.1
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!AACPIButtons 6.1
>!ARTC 2.0.1
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 402
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
@Dont_Steal_Mac_OS_X 7.0.0
@kec.!AEncryptedArchive 1
>usb.cdc.acm 5.0.0
>usb.serial 6.0.0
>!UAudio 416.2
>!AAudioClockLibs 140.1
>driverkit.serial 6.0.0
@kext.triggers 1.0
>DspFuncLib 340.2
@kext.OSvKernDSPLib 529
@kext.AMDRadeonX4100HWLibs 1.0
@kext.AMDRadeonX4000HWServices 4.0.8
>!AHDA!C 340.2
|IOHDA!F 340.2
|IOAudio!F 340.2
@vecLib.kext 1.2.0
>usb.IOUSBHostHIDDevice 1.2
>!AGraphicsControl 6.5.7
@kext.AMDSupport 4.0.8
|IO!BSerialManager 9.0.0
|IO!BPacketLogger 9.0.0
|IO!BHost!CUSBTransport 9.0.0
|IO!BHost!CUARTTransport 9.0.0
|IO!BHost!CTransport 9.0.0
>IO!BHost!CPCIeTransport 9.0.0
|IOAVB!F 1040.6
@plugin.IOgPTPPlugin 1040.3
|IOEthernetAVB!C 1.1.0
|CSR!BHost!CUSBTransport 9.0.0
|Broadcom!BHost!CUSBTransport 9.0.0
|Broadcom!B20703USBTransport 9.0.0
>!AIPAppender 1.0
>X86PlatformPlugin 1.0.0
>IOPlatformPlugin!F 6.0.0d8
>!A!ILpssUARTv1 3.0.60
>!A!ILpssUARTCommon 3.0.60
>!AOnboardSerial 1.0
|IOSerial!F 11
|IOAccelerator!F2 462.8
>!ABacklightExpert 1.1.0
|IONDRVSupport 597
>!ASMBus!C 1.0.18d1
>!AThunderboltDPOutAdapter 8.5.1
@!AGPUWrangler 6.5.7
@!AGraphicsDeviceControl 6.5.7
|IOGraphics!F 597
|IOSlowAdaptiveClocking!F 1.0.0
>usb.cdc.ecm 5.0.0
>usb.cdc.ncm 5.0.0
>usb.!UiBridge 1.0
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltDPInAdapter 8.5.1
>!AThunderboltDPAdapter!F 8.5.1
>!AThunderboltPCIDownAdapter 4.1.1
>!ABSDKextStarter 3
|IOSurface 302.14
@filesystems.hfs.encodings.kext 1
>!AActuatorDriver 5450.14
>!AHIDKeyboard 228.2
>!AMultitouchDriver 5450.14
>!AInputDeviceSupport 5450.4
>!AHS!BDriver 5450.8
>IO!BHIDDriver 9.0.0
>!AHSSPIHIDDriver 63
>!AXsanScheme 3
>!AThunderboltNHI 7.2.81
|IONVMe!F 2.1.0
|IO80211!FLegacy 1200.12.2b1
|IOSkywalk!F 1.0
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
>!AHSSPISupport 63
>!A!ILpssSpi!C 3.0.60
>!AHPM 3.4.4
|IOThunderbolt!F 9.3.3
>!A!ILpssI2C!C 3.0.60
>!A!ILpssDmac 3.0.60
>!A!ILpssI2C 3.0.60
>!A!ILpssGspi 3.0.60
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
|IOTimeSync!F 1040.3
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 9.0.0
|IOReport!F 47
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 533.120.2
|IOUSBMass!SDriver 210.120.3
|IOSCSIBlockCommandsDevice 456.121.3
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 456.121.3
>!AMobileFileIntegrity 1.0.5
$!AImage4 4.2.0
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.Libm 1
@kec.corecrypto 12.0
"This Macbook has a "new" board with original fault a short on C4928 (PP3V0_MESA_CONN)."
Not sure if I correctly understood; original board was changed because of a shorted cap?
Anything pops up starting in AHT?
Apart of PRAM reset, do SMC reset too.
Save the data and reinstall macOS from Internet Recovery.
You must discard a software issue first.
Beeldbuisje
original board has lots of interrupted ways. Especially in the area of the CD3215 chips. So this wasn't fixable anymore. The previous owner tried to fix this board by himself with no luck and lots of damage.
I bought a secondhand defective board in the US (=cheap). This board had the short on C4928. This is fixed, after that the board works fine except the sleep-crash behavior.
AHT says everything is fine.
Did both resets: PRAM and SMC.
Did a reinstall of macOS twice.
The new board came with Catalina installed. I putted a USB drive with bootable Monterey and installed this OS the first time from the USB. The second time I reinstalled using Internet Recovery.
Cleared the SSD completely and reinstalled OS in both situations.
I could try to reinstall his original software from 2017 High Sierra and update from High Sierra to Monterey to be sure his Touchbar's firmware is updated? Or should this be useless?
Is worth to try with original macOS.
Just in case, check SMC_LID/_LEFT/RIGHT signals; when colse open lid.
Beeldbuisje
A little feedback...
I made a bootable USB drive of High Sierra on this machine. I had to: via Internet recovery wasn't possible anymore. Files were damaged on the server was the feedback.
Because there're lots of programs not compatible anymore with HighSierra, I updated to Catalina from a running HighSierra.
Never any Kernel Panic since this action.
Because the machine runs 9h on a single charge compared to hardly 6h on Monterey, for the time being, he stays on Catalina.
