A1707 critical update
hgoncalves
I've an A1707 that is always asking for a critical update, even when installing a new macOS.
The disk is reconized in restore mode, it has Monterey instaled, and already run first aid with no errors.
Should I start with a DFU restore?
Don't know where to start.
Can you help?
hgoncalves
Following Luke's post, I found that with the touchbar disconected, and in safe mode, I was able to install Big Sur, and now the mac boots in safe mode, and so, I supose that the problem is on the touchbar (not sure)
Shoul I replace U3900? Is there any way to phisical disable touchbar?
hgoncalves
Hi.
Client said that one morning this error appeared.
J4401 voltages:
PIN 3 = 0.450V
PIN 5 = 0.355V
PIN 9 = 0.402V
PIN 11 = 0.417V
PIN 15 = 1.8V
PIN 17 = 1.8V
PIN 21 = 1.8V
PIN 23 = 1.8V
PIN 4 = 0.330V
PIN 6 = 0.360V
PIN 10 = 0.062V
PIN 12 = 0V
PIN 18 = 3.3V
PIN 20 = 3.3V
PIN 22 = 3.3V
J4402 voltages (with J4401 cable conected):
PIN 1 = 0V
PIN 3 = 0.224V
PIN 7 = 0.324V
PIN 9 = 0V
PIN 13 = 1.790V
PIN 15 = 0V
PIN 19 = 0.520V
PIN 21 = 1.8V
PIN 2 = 0V
PIN 4 = 0.460V
PIN 8 = 1.8V
PIN 10 = 0V
PIN 14 = 1.8V
PIN 16 = 1.8V
PIN 18 = 1.8V
PIN 20 = 1.8V
PIN 22 = 5V
You must check with both cables connected.
I recommend you to test the machine with known good touchbar.
