A1708 820-00840 no power
hgoncalves
Hi.
I have an A1708 820-00840 that has 20V from ampmeter, but 0A.
PPBUS_G3H seams to be shorted, but I can't see nothing hot (injected 1.5V).
PPBUS_G3H = 0V
Diode reading on PPBUS_G3H = 0.002
Can you help?
Check (ohm scale) if you get same reading on any big coil.
Use 10-20A PSU, setting amp limit to max first.
Did you set amp limit to max?
Even 3W should heat something on the board.
Use powerful cables; your interest is not heating the cables.
An IR cam may help you to find the culprit.
hgoncalves
Yes, I set the amp limit to max (5A), and I already use the thermal cam, but I can't see nothing hot.
With the amp limit to 5A, injecting 1.5V, only consumes around 2A.
Shall I increase the voltage*?
