A1932 820-01521-A
hgoncalves
I have an A1932 820-01521-A that puls 20V from ampmeter, but only consumes 0.20A from bench PSU.
I already tried the revive and restore without sucess. Can it be T2 related problem?
Can you help?
hgoncalves
No history. Client says that It stoped sudently.
The DFU fails with error (I'm doing the DFU with a M1 Pro. Not sure if incompatible):
"The System cannot be restored on this device.
Gave up waiting for device to transition from DFU state to DFU state.
[com.apple.MobileDevice.MobileRestore -OXFCA (4042)]"
PP5V_G3S = 5.122V
PP3V3_G3S = 3.294V
PP1V8_G3S = 2.936V (not sure if the value is normal, but recheked on several places with same value)
PP0V9_SSD = 0.9V
PP1V8_SSD = 1.8V
It seams that it is rebooting. It goes from 0.03A to 0.20A, and reboots.
Did you test the board alone on the desk?
CPU core tries to appear?
Check for short and voltage pulse on all big coils.
Inspect audio board/flex for liquid signs.
hgoncalves
I did tested it on the desk alone, without anything else connected, and it has the same behavior.
CPU core is always stable at 0V.
All big coils seams to be ok, except L7210, L7430 and L7410 that only have 8 ohm to ground and 0.012 on diode reading (again, not sure if normal value) and no pulse.
L7030, L7690 and L7670 have voltages that oscilates whille rebooting
Don't know if it relavant, but the only thing that gets hot is the T2chip, but with only around 33º C, and U3200 with around 30ºC
Audio board seams ok.
hgoncalves
Sorry. I haven´t undestood it.
U8240 - PP1V2_S0SW = 2.6K ohm and steady 0V
U8210 - PP3V3_G3S = 7.28M ohm and Oscilates from 0V to 3.298V
U8220 - PP1V8_G3S = 450K ohm and Oscilates from 0V to 1.803V
U8225 - PP3V3_G3SSW_SNS 0 = 5.2M ohm and 0V
U8200 - PP3V3_TBT_X_S0 = 60K ohm and 0V
Why do you still continue to check in ohm scale for high resistance to ground?
How many times need to repeat about diode mode?
Switch to ohm scale ONLY for very low readings; usually under 0.010...
I don't actually have any 01521 for comparison, sorry.
"PP1V8_G3S = 2.936V"
If true, check PP1V8_SLPS2R too.
hgoncalves
SORRY!
I must have made a mistake and misread it. The actual value of PP1V8_G3S is oscilating from 0V to 1.802V
