A1932 820-01521 DFU error
hgoncalves
I have an A1932 820-01521 that enters in DFU mode, but always gets an error before the end.
Sometimes it says that he needs to install a software update (on the Mac with the Apple Configurator 2), I start the update, but at the end it says that it can not update , because nothing was found on the server.
Most of the times ends with an error on the img.
Can you help?
Sorry, here it is the ing. I corrected the inicial post also, with adicional information about the update error
Hi.
I've tried now with audio flex disconnected and a good trackpad but still got an DFU error (a different one):
Check diode mode to ground on all secondary power rails.
Compare readings with good board.
Just in case, try DFU shorting 3V3_S5 to ground.
