A1989 (820-00850) RAMCFG
I have upgraded the RAM on a test machine from 8GB to 16GB (SKhynix 9CCNNNBJTAL). What is the correct MLB_RAMCFG strap setting for this configuration?
Proposed 16GB Config:
  • MLB_RAMCFG0 = Low (1k ohm resistor to ground)
  • MLB_RAMCFG1 = Low (1k ohm resistor to ground)
  • MLB_RAMCFG2 = High (Pull-up / No resistor to ground)
  • MLB_RAMCFG3 = Low (1k ohm resistor to ground)
  • MLB_RAMCFG4 = Low (1k ohm resistor to ground)
Original 8GB Config:
  • MLB_RAMCFG0 = High (Pull-up / No resistor to ground)
RAMCFG0-2 look good (in theory).
RAMCFG3/4 should meet your chips specifications.
"MLB_RAMCFG2 = High (Pull-up / No resistor to ground)"
This looks strange, for original 8GB.
So we can never trust Apple...
So it’s fine?
Yes, test it at least.
The strange thing is that original configuration (8GB) you've found on the MLB, corresponds to Micron 16GB 2133MHz Die Rev A.
SMMRepair
The T2 chip on the board must support the increased RAM. This is a big issue on the 00850 because of how many T2 model chips there are. If the board you pull the RAM from doesn't have the identical-model T2, it won't work, even if you configure the CFG resistors properly.
