A1990 820-01041-07 no power
hgoncalves
Hi.
I have an A1990 820-01041-07 with no power.
The mac had contact with a bit of water, and U9080 area was a bit oxidated, and the area near UB300 also seamed to be a bit oxidated (very few signs), but because it has 20V I didn't replaced it.
I've replaced RB258 because it was a bit oxidated, and U9080 because that area also had a bit of signs of oxidation.
I have 20V on ampmeter, and the ampeter progressive reaches 0.255A and then it reboots.
I can't see anything else damaged, and couldn't find anything shorted.
Do you have any idea to where I should focus?
Can you help?
hgoncalves
Hi.
I can't se nothing shorted on the NANDs
Can you please help diagnose a dead NAND?
UB300 also had a litlle sign of liquid, but his LDOs and CC1/2 diode readings are ok. . Can it be UB300?
hgoncalves
Is there any way for me to be sure that it is a NAND problem, so I can propose to the client to replace all NANDs?
All USB-C ports switch to 20V?
Did DFU restore after changing NANDs?
BTW, did you change all NANDs, both sides?
hgoncalves
Hi.
Yes, all USB-C ports switch to 20V. However the Mac seams to be rebooting after a few seconds, but maintaining 20V.
Yes, I've done the DFU restore, however it fails because the reboot I suppose (the error was give up waiting for the device).
Yes, I've changed all 4 NANDs (2 per side).
hgoncalves
Hi.
Erasing U4770 didn't solved the problem.
I still get the DFU error (ing attached)
