A1990 No power
ronaldo
Hi, I have an A1990 board 820-01041-A, no corrosion or liquid.
The NANDs on the left (immediately are getting warm after 10 seconds or so, then get hot - no power. The trackpad was clicking, after trying DFU revive it doesn't click any longer.
Board is taking 20V and bouncing between 0.1A and 0.7A
PPBUS_G3H is present bouncing between 10.6V and 12.5V
PP2V5_NAND_SSD0 is shorted to ground
PP1V8_SSD0 is present 1.8V
I was reading on RepairWiki that what is important is that PPBUS_G3H doesn't go direct to the NAND - pardon my stupid question but how can one check this? Would the PP1V8_SSD0 and PP2V5_NAND_SSD0 lines be ~12V?
I will check tomorrow under thermal camera once I am back in the shop, with my novice knowledge does this mean SSD is dead?
ronaldo
3 SSD Nands are getting warm/hot, and there was scorch marks on U9080.
PP2V5_NAND_SSD0 is 1.5Ohms, removing U9080 and U9000 has made no difference to this resistance.
After injecting 1V without the two SSD controllers present nothing gets hot
So would it be accurate to say at this stage one or more of the SSD NANDs have internal short? Or the only way is to take U9080 U9000 from working board and test?
