A2141 820-01700-A no power
You can inject even 2V, but may need a thermal cam to detect snall temperature differences.
Remove CPU heatsink first...
hgoncalves
U8220 seams to be the only component that gets hot but even after removing it, the short remains, and PP3V3_G3H_T seams to also be shorted (0.003 in diode reading). U7800 also gets hot when injecting 2V on PP3V3_G3H_T.
I don't have a same model donor board.
Can I use the same components from a different model board?
hgoncalves
Can you help with the board model. I can't find those components on otehr schematics. Do you know any other model?
Look at "Power FETs" page in other schematics.
You may find chips with different name, but same function.
hgoncalves
PP1V8_G3S now has 0.250 in diode reading, but 0V. The power isen't cycling anymore, but it 's still at 5.12V and 0.26A
hgoncalves
No it isen´t recognized in DFU. However, I notice that with the battery conected it pulls 20.5V and 0A from ampmeter, on all USB ports, and without battery connected only 5.12V and 0.26A
hgoncalves
I can't find R7835. Only C7835. Are you sure?
All coils have low diode reading:
Diode reading Good board:
L7813 = 0.349
L7817 = 0.050
L7816 = 0.050
L7814 = 0.278
L7815 = 0.278
L7806 = 0.010
L7807 = 0.010
L7808 = 0.010
L7809 = 0.010
L7811 = 0.037
L7812 = 0.037
L7810 = 0.327
R7814 = 0.279
Diode reading bad board:
L7813 = 0.016
L7817 = 0.012
L7816 = 0.012
L7814 = 0.002
L7815 = 0.002
L7806 = 0.021
L7807 = 0.021
L7808 = 0.021
L7809 = 0.021
L7811 = 0.048
L7812 = 0.048
L7810 = 0.383
R7814 = 0.002
hgoncalves
R7900 seams to be ok and has 0 ohm resistance.
After replacing U7800 all the doils diode readings are likely the same.
After close inspection, I notice that U8250 seams to be a bit blown and is geting a bit hot on thermal cam. I don't have a donor board to it. Do you know other board model that I can use as a donor for U8250?
