A2141 battery no charger
lincev
Good morning, I have this equipment with the problem that it does not charge the battery. I am using an original 87w magsafe and I have tried to change the battery but the problem continues. any ideas? Thanks everyone for ur help
Is the battery recognized at least?
Any history available?
Be sure the flex cable makes good contacts; check the terminal from battery side too.
lincev
The computer did not turn on, with a new battery it did turn on but the message "the battery is not charging" came out one day it stayed on and went down to 5% now it turns on the apple comes out and halfway through the progress bar it turns off.
I'm going to check the connections as it says
lincev
I have tried several cables, including new ones, and I can't finish the process.
I am going to try to charge the battery again and repeat the process with a battery with at least 50% charge
lincev
sorry I have one, thanks for all. We will talk when you receive the tool you can do this test
