A2159 no power
2try’s
Hello, i have 820-01598-A board that not powering on. usb-c tester shows that it takes 20v from original charger and going up to 600mA then drops to 430mA and stays . Basic voltages (at least the ones i mesured) are present, cpu is getting hot and missing some voltages
ppbus_g3h - 12.62v
pp3v3_g3h - 3.3v
pp3v3_s5 - 3.3v
pp1v8_g3s - 1.8v
pp1v8_s5 - 1.8v
pp5v_g3s - 5.1v
CPU
PPVCCGT_CPU_PH1 - 0v
PPVCCGT_CPU_PH2 - 0v
PPVCCEDRAM_S0_REG_R - 0v
PPVCC_CPU_PH1 - 0.817v
PPVCC_CPU_PH2 - 0.818v
PPVCCSA_CPU_R - 1.022v
PP0V95_S0_CPUVCCIO_REG_R - 0.958v
I don't see missing voltages.
EDRAM voltage not present on boot normally, and iGPU nor even later; only when high graphics load is detected.
Any history available?
In case of BIOS issue, try DFU restore.
Be aware, will erase SSD.
You can try revive instead, but not always helps.
turned out that it was bad u2890, after replasing with good one from same board it started to show in dfu mode
now when i try to restore it shows me error (9)
