A2251 820-01949-A
hgoncalves
Hello.
I have an A2251 820-01949-A with no power, and client said it stoped working overnight.
t has 20V on bench PSU, but took only 0.2A.
In DFU restore I get the error in attach.
Can you help?
hgoncalves
Hi.
Thanks for the OpenBoardData Project.
I think I've made a mistake, and measured PP2V5_NAND_SSD0 when it was hot, because right now I have the correct value there : 0.410 on diode reading, and 2.5V.
Any other idea?
hgoncalves
Hi.
After erasing SoC ROM U4770, the mac now stays at 5V and isn't recognized in DFU.
However, I have a strange behavier: now I only have again 0.136 diode reading on PP2V5_NAND_SSD0.
Sometimes I get the corrrect value, and other times I don't.
Any idea? Can I inject 2V there when I have a wrong reading there?
hgoncalves
OK. tks.
Shall I restore it?
hgoncalves
Hi.
Still stuck at 5V and not recognized in DFU.
PPBUS_G3H = 12.28V
PPDCIN_G3H is 5V
PP3V3_G3H is 3.3V
U3100_X diode readings:
PP3V3_UPC_X_LDO = 0.506
PP1V5_UPC_LDO_CORE_X = 0.529
USBC_X_CC1 = 0.585
USBC_X_CC2 = 0.583
U3100_T diode readings:
PP3V3_UPC_T_LDO = 0.501
PP1V5_UPC_LDO_CORE_T = 0.525
USBC_T_CC1 = 0.572
USBC_T_CC2 = 0.571
U3100_R diode readings:
PP3V3_UPC_R_LDO = 0.510
PP1V5_UPC_LDO_CORE_R = 0.527
USBC_R_CC1 = 0.572
USBC_R_CC2 = 0.570
U3100_W diode readings:
PP3V3_UPC_W_LDO = 0.501
PP1V5_UPC_LDO_CORE_W = 0.527
USBC_W_CC1 = 0.593
USBC_W_CC2 = 0.591
hgoncalves
Hi.
I've just erased U4770.
Nothing seams to be wrong on that area.
Everithing is in place, and I can't see nothing wrong.
If machine was recognized before in DFU mode, something happened when you worked on it.
So check for knocked off components, damaged traces, or connectors.
hgoncalves
Hi.
My mistake. Don't know what I was doing wrong, but you're right.
The Mac is in DFU mode, however, I don't finishes the DFU restore. It always crashes before ending.
