a2289 820-01987-A not turning on, stuck at 5v
Hi, I have a a2289 stuck at 5v 0.065a (both ports same exact reading). 12.28v at F7000. can't find any shorts, seems like voltages are there. Not showing in dfu mode(also tried to force dfu and still doesnt show). Came in from another shop, they said it was working when customer brought it in and needed a battery, they tried to change battery and then it stopped turning on.
Inspect for damaged connectors and broken traces.
This board should start with 61/87/96W charger alone, without battery; check that.
Do you get correct 3V3_G3H_RTC voltage?
Hi, Thank you
only thing i saw damaged was DZ3302 was missing, replaced from donor board. Doesn't start with or without battery on 96w charger.
3v3_G3H_RTC reading 3.3v
This is what i'm getting diode readings:
L9080 - 0.394
L8410 - 0.806
L7670 - 0.400
L7690 - 0.386
L7030 - 0.467
L7702 - 0.036
L7420 - 0.004
L7410 - 0.004
L8100 - 0.173
L8102 - 0.090
L7270 - 0.014
L7210 - 0.004
L7220 - 0.004
SMBUS_3V3_BATT_SDA - 0.927
SMBUS_3V3_BATT_SCL - 0.904
