mgladin
Hello,
I have a MacBook that was taken to UBreakIFix for a battery replacement. However, they couldn't get the computer to boot even with a new battery and diagnosed it as a motherboard issue, sending the customer on their way. The customer then brought the MacBook to our store.
Upon checking it in and starting the diagnostic process, I found a consistent 0.3A draw. A visual inspection of the board revealed that components DZ3302 and DZ3352 were physically damaged, with parts missing. I replaced these components using parts from a donor board, which resolved the 0.3A draw issue.
However, a new problem emerged. The computer will not boot, but it will stair-step charge, reaching about 1.4A-1.5A at 20W before resetting and repeating the process every 30 seconds. Using a thermal camera, I identified two hotspots: one at L7030 and the other at Q7030.
Upon further investigation with my multimeter, I found no issues with the inductor but discovered a potential short to ground using diode mode on CHGR_LX1 when testing the test point below Q7030. Switching to Ohms mode, it read 2.0-2.1 ohms. I replaced Q7030 to rule out issues there, but the problem persists.
I’m unsure of the next steps. I could try replacing U7000 on the top side of the board, but I can't confirm anything since the short detection in diode mode and parts heating up only occur with the battery connected.
Any advice would be greatly appreciated. Thanks in advance for your help!
