A2337 Not Charging
Instafixx
Works well with a charged battery but doesnt charge. It show the charging sign but the charge doesn't increase.
SCL/SDA lines are okay.
I wanted to know if battery percentage decreases normally, when working.
What voltages do you get on the board, with charger alone?
3V3_S2 present.
Since it turns on with a charged battery - I am assuming CPU core voltages should be normal.
Which voltages you want me to check?
all voltages given above are without battery.
CPU_SRAM_AWAKE 0V
ECPU_AWAKE 0V
VSNS_VDD_ECPU 1.8V
VSNS_VDD_PCPU 0V
VSNS_VSS_PCPU 0V
Gave up waiting for device to transition from DFU state to DFU state. [com.apple.MobileDevice.MobileRestore – 0xFCA (4042)]
While restoring !
