A2338 820-02020 no loudspeakers
hgoncalves
Hi.
I have an A2338 820-02020 without sound on the loudspeakers.
There is no sound from the internal speakers. However, there is sound when connected to headphones.
The customer indicates that he have already took the equipment to another repair company, but they were unable to understand the origin of the problem.
JR800/50 have all diode readings OK
JR900 disconected but same result.
Can you help?
hgoncalves
The customer said the speakers stopped working overnight.
This model dosen't have an audio board I think. By audio board, do you mean the Audio Jack Flex Cable? If so, I haven't replaced it, because even with the cable disconnected, there's still no sound, and with the cable connected I get sound if I use headphones (but not through the speakers).
Shall I replace it?
The audio jack has some contacts which decide to switch between speakers and headphones.
Your problem may be there.
hgoncalves
Hi.
AUDIO_JACK_TIP = 3.4V and drops to 0V when audio jack is pluged in
AUDIO_JACK_RING_SNS = 3V and drops to 0V when audio jack is pluged in
