A2338 820-02020 PP3V8_AON Shorted
Instafixx
Board Seemed to have gobe through an ultrasonic cleanse.
PPBUS_AON is 12.3V
AMP Meter Stuck at 5V.
PP3V8_AON is shorted. Diode mode reading .002
Found LR503 to be getting hot after injecting voltage.
Removed LR503. 3V8_AON is now .360 (Diode to Ground).
But PP3V8_CODEC_VP is still shorted.
Removed UR500 the short is gone.
Before Replacing - tried to see if the i get 3V8_AON voltage but it is still 0V.
P3V8AON_PWR_EN IS 5V
CHGR_EN_MVR IS 5V.
Instafixx
Pin 5/7 is 5V
Pin 6 is 0V
Diode Mode to Ground is .056
PP5V_S2_P3V8AON_VDRV
Reading Across Pins
R5900 is 0.5 Ohms
C5700 is 38 Ohms
Removed R5900.
PP5v_S2 is shorted with Diode Mode 0.056
P5VS2_EN
DIODE Mode Reading is .366
Voltage is 0.
PPVIN of UC300 is same as PPBUS.
UC300 looks dirty also on the borders pins. Removed it. Still Short Remains.
Injected Voltage at PP5V_S2. i dont know how but short removed. I get around .350 value to ground.
Put Still Pin 6 of U5700 is 0V
Still missing 5VS2_EN?
Something is damaged on the 5V_S2 power rail.
Possibly corrosion on its feedback network; that can cause random overvoltage.
"Injected Voltage at PP5V_S2"
How much voltage directly?
If inject high voltage, can burn the culprit without noting it.
The idea is to start with low voltage (1V) and check if something gets hot; increasing the voltage, if need.
Instafixx
Started with 1V. But nothing got hot.
Gradually increased it step by step to ultimately 3V. The current draw was very low.
I have a 5A PSU.
Check all Q5800/20/40's adjacent components.
Compare diode mode readings around U5700 and Q5800/20/40 with good board.
Instafixx
I dont have a Good Board.
But while checking with OpenBoard Data
Diode Mode Readings to Ground which seem off
R5825/6 is 1.02
P3V8AON_BST2_RC - .976
P3V8AON_BST3_RC - .976.
Should i check further ?
