GoliathX0X0
EDITED: Hello! I’m new to this forum — and I did something pretty stupid.
I picked up a used top case and an aftermarket display, then swapped over the logic board and Touch ID. Everything worked fine until what I did next.
I got a popup to “complete the service,” so I tried to finish the pairing process, but it failed. I assumed the aftermarket display was the issue, so I tried again — but in the process I disconnected the eDP cable. Since then, the internal screen hasn’t worked at all: no image, no backlight, and also no camera/light sensor. I tried the original damaged screen and no luck. It does still output to an external display.
EDITED TO ADD: There are no signs of liquid or physical damage at all on the board.
I attempted a DFU restore/revive, but it failed, and now it won’t boot into macOS. It does boot into Recovery on an external display.
Here’s what I have available right now:
I have done some research and some forums are pointing to RD560. Before I prod at it. I would greatly appreciate help to repair this MacBook. I have attached images of the laptop with the screen working and the following diagnostic screens I came across.
Thank you,
G
- Hot air station + iron
- Binocular microscope
- Multimeter + other tools
- Board schematic
- Decent soldering experience and understanding of electronics
Thank you,
G
