A2485 820-102382 not powering on
hgoncalves
Hi.
Hi have an A2485 820-102382 that seams to try to booy (20V and 0.30A) , but then reboots. It does that on all ports.
Only have schematic fot the 820-02100, and don't know where to start.
No big coil seams to be shorted, and cleibt said it just stoped working. No visible damages on board.
I can't see nothing getting hot on IR cam.
Can you help?
Hi.
I've done both.
Board alone on the working bench, and board alone (with just a known good battery) on the bench.
Same result.
Hi
Everithing seams to be normal (besides rebooting).
The only two things that are a bit hot, are U9400 and L5800.
Hi.
It isn't recognized in DFU.
The U9400 flashes on the IR camera when it reboots, but I can't see nothing shorted around it.
Does it worth replacing it? If so, can I use one from a different board model?
Hi.
Apparently I have a leak in one of the NANDs. PP2v5_NAND0 has a reading of 0.173 on the diode mode.
Can you advise me on where to buy these NANDs?
