A2485 MacBook Pro / 820-02100-A board / 5v .11a / Logic board failure /
zeydullak
Hello guys,
We have a A2485 MacBook Pro that is using only 5v and .11a, when connected nothing happens at all.
The customer said it is not water damage and some type of other failure.
Here are some voltage readings of the main power lines.
PPBUS_AON -> 12.3v
PVBAT_AON_CHGR_R -> 12.30
PPBUS_NAND0 -> 12.30
PPBUS_AON_LUXE -> 12.30
Please advise on what we should do next.
Regards,
Zeydulla.
Don't waste time checking the same power rail in various points.
Aren't all these lines PPBUS_AON???
What about 3V8_AON and U8100 LDOs?
Any other voltage detected on the MLB?
Check U7700 LDOs too.
zeydullak
3V8_aon -> .0v
PPVDD_ECPU_AWAKE -> .0V
PP0V81_S1_SRAM -> .0V
PP1V8_S2SW -> .0V
PPVDD_AMPH0_S2SW ->.0V
PP1V2_AWAKE -> .0V
PP0V575_S1_VDDQ0 -> .0v
Short to ground.
Use voltage injection method to find the culprit.
As always, start with just 1V; set amp limit to max first.
