A2681 - 820-02536 Air M2 5V 35mA
jadao
This board came in liquid damage near the daughter board and slightly on the logicboard.
Cleaned everything, checked for shorts and plugged in usbc charger, I see only 5V 35mA. Don't know where to start with this board.
I took this measurements but it doesn't give me any clue and have no other reference board.
PPBUS_AON 12.3V
PP3V8_AON 0.4V(0.309 DIODE MODE)
PP5V_S2 0V (0.230 DIODE MODE)
PP3V3_S2 0V (0.371 DIODE MODE)
PP3V3_AON 0V (0.365 DIODE MODE)
jadao
Pin 8 : PPBUS_AON 12.3V
Pin 7 : PP5V_AON 4.99V
Pin 5 : P3V8AON_PVCC 4.99V
Pin 12: P3V8AON_PWR_EN_R 4.46V measured at the zero ohm R5710 on both sides 4.46V
jadao
I replaced U5700 501CR17 with U5700 501CR0B coming from A2337 board and i have exactly same results. 5V 35mA with same values on pins 8, 7, 5 and 12
I had doubts for the chip but schematics shows same pinout...
Not sure if are directly compatible.
Check all surrounding resistors and traces; also the capacitors.
jadao
I ended up puting back the original chip U5700.
I checked also all surrounding components near u5700 and evrything is in spec. Liquid was more near speakeramp UR700 and UR730.
Something may probably help, I injected 5V at PP5V_S2 rail (it is not shorted) and plugged the usbc charger, surprisingly the meter is going to 20V 0,455A and the board is booting but bootlooping, I can even see the apple logo with the progress bar, it doesn't stuck but just doesn't have time to finish and it bootloops.
Same if I hold power button I will see loading options message then it will bootloop.
I plugged the battery in just in case but it didn't help it's bootlooping even with the battery only.
When I shut off external 5V power supply, board stays at 20V bootlooping to 5V and coming back to 20V a couple of cycles and then it comes back to 5V 35mA constant until the next time I provide external 5V to PP5V_S2.
Any hope or hint to check further or I am just bypassing a mountain of conditions...
Thanks!
jadao
As soon as I get 20V on usbc-meter with providing at the same time external 5V to PP5V_S2 I will get 3V8_AON.
usbc meter cycles as follow: 5v->20V-> 0v and repeat 5v->20V-> 0v it stays long enough at 20V to be able to see progress bar going to 25% and then it cycles again.
When I shut off external 5V, PP5V_S2 (5V) 3V8_AON remains on the board both during 3-4 cycles (usbc meter 5v->20V-> 0v) and then it comes back to usbc meter 5V 35mA with no more 3V8_AON (0V) and no more PP5V_S2 (0V).
I don't know if it's random or particular power sequence I am messgin with because I just tried now, and after shutting off external 5V, board stay on for 15 minutes at 20V I had a screen with exclamation mark and the famous support.apple.com/mac/restore I think it's normal to shut off after a while when you do nothing at this screen (restore page). But after that it comes back to 5V 0.35A and I am not able to reproduce that.
Tried also dfu to see what happens but it doesn't work.
No need to repeat DFU, if already got the mac/restore message.
You should try now internet recovery.
BTW, this machine has USB boot enabled by default; check what happens.
jadao
Unfortunately I wasn't able to reproduce the same situation, can't load options to go with internet recovery, machine keeps constantly rebooting even with 3V8_AON..
Thanks for the usb boot trick didn't know that on this recent machine but the machine doesn't pick up external usb drive...neither usb mouse or keyboard.
I will stop on this one, M2 may got hit by liquid near speakeramp circuitry...
Thanks for your support always learning
