A2681 - Repair Assistant / Touch ID sensor
I have a MacBook Air M2 (2022/A2681) here that was missing its Touch ID sensor. I have an OEM Apple replacement, but it isn’t being recognized by the Repair Assistant; it just says 'Touch ID problem'.
Output/Diagnostics:
- Connectivity: Good
- Calibration: Good
- Test Finger: Not Good / Won’t recognize it
Is the only way to 'trigger' the Repair Assistant to order a brand-new Touch ID sensor directly from Apple Self Service?
R2004/5 = 20ohms (1.250)
Yes I have tried like 2-3 diffferent boards, I have noticed that PP16V0_TOUCHID_FILT_CONN (0.616) is missing.
TOUCHID_PWR_EN = 1.2V
Boost enable comes from Touch ID.
Did you test with known good one?
Just in case, check RT0403.
Also inspect J0401.
Yes, I have used a known good Touch ID.
RT0403 = 0ohms, fine.
J0401 = Also fine.
Is it possible that "TOUCHID_BOOST_EN" only gets enabled when the Touch ID is successfully paired with the Mac?
TOUCHID_INT = 0.306
TOUCHID_PWR_EN = 0.305
SPI_TOUCHID_CLK = 0.585
SPI_TOUCHID_MISO = 0.590
SPI_TOUCHID_MOSI = 0.590
So I guess the (main) logic board can be excluded as "failure point", do you agree?
Everything is present 1.8V LDO, 3.0V LDO except 16.0V LDO and TOUCHID_BOOST_EN.
I had a problem with missing boost voltage on A2442 machine.
However Tahoe was able to pair it, just not detecting fingerprints.
Check diode mode to ground at J0401; compare with good machine.
Also check all the resistors related with SPI_TOUCHID lines; RT0401/3/10-13.
Diode values are looking good.
I have now replaced Touch ID and daughter board with a new one, issue still exists.
When I received the board the following components were missing:
- L8101
- L8102
- L82B1
- L82B0
- L8122
- L8120
Note: Components are now present otherwise the board wouldn't boot.
That has nothing to do with it, I guess so, right?
