You're asking me to check and if it's low, and to remove the cap if it is. How can I know what qualifies as a low reading??
Diode mode to ground is 0.481. I have not removed the cap. Let you know if you think I should remove the cap and test again.
Thanks
Thanks, DFU blaster worked great for getting it seen by Configurator. I'll use that again for sure.
It gets to the last step of the restore, at which point it reboots and then says "unable to complete restore" or something along those lines.
The boot looping is not happening any more.
Now, the chime happens, Apple logo appears for a split second and then it is just stuck on a blank screen.
20V up to 500mA as the Apple logo appears, and shortly after is just stuck at around 150-160mA - inactive but on.
No video output to external monitor.
Okay so it appears as if the problem may be the display assembly...
DFU restore still did not work with the LCD disconnected, however I was able to boot with an external monitor connected. I've since found the device is activation locked! Now I will have to contact the eBay seller as they said there was no activation lock...
Is it possible that the DFU restore didn't progress due to activation lock?
The results are repeatable now:
Screen connected, the device is stuck in boot loop. No keyboard backlight, no caps lock LED.
Screen disconnected, the device boots as expected.
