I got an A2779 which has a black display. External monitor works.
I connected a working display that works fine. of course it has the ghost problem.
So I thought the display was defective. I ordered two displaypanels then I disassembled a display of this series for the first time and replaced the two chips in one display
the angel sensor is connected and with the calibration tool i checked that it works
now I have different results.
1. foreign display
everything works except for the usual misrepresentations
2. display with original china chip without any changes
it comes the dong
backlight does not work
the apple appears, nothing more, it goes out. this is repeated a few times, then the circle with the exclamation mark appears
3. display with re-soldered original chip
it comes the dong
backlight doesnt work
the apple appears, the backlight does not work, it goes out. this is repeated a few times, then it stays off
now i have reflowed the two original chips again but there is no other result.
unfortunately there are so many factors that i cannot find out what exactly is defective.
i thought the display cable was faulty but when the apple comes it should work.
then i thought maybe the two chips are not soldered properly or defective but even then i thought could it not be the apple sign?
i thought with the display without changes, i.e. still with the chip from china, at least a picture and backlight should come, even if only as a ghost picture.
the device boots up fine without a display. until the keyboard backlight lights up i can click the trackpad.
with the original replaced chip variant, where only the apple is present, the keyboard does not light up and the trackpad cannot be clicked.
need some help please
1. foreign display
it comes the dong
it comes the dong
