A3114 Trackpad and keyboard not working
kashitozu
I have a MacBook that won't turn on (1).
I replaced the UF500 and UF400, and it worked perfectly.
I have another MacBook A3114 that won't turn on (2)
When I wanted to swap the motherboards and tried them in each other's chassis, I was surprised to find that in the first chassis (1), the trackpad and keyboard no longer worked.
In the other chassis (2), my motherboard (1) did the same thing: the trackpad and keyboard didn't work.
So I ordered another trackpad, ribbon cable, and another keyboard, but I'm getting the same result.
Where do you think the problem is coming from?
Okay, let's see about that. When I reassembled it the first time, I lost the backlighting, so I replaced the UP700 and it worked perfectly.
We use XinZhiZao as software, but we don't have the values. If you have your schematics and board view or software, please send them to us.
Did you test with lid sensor disconnected?
Bad lid signal can disable trackpad; and keyboard will not work without trackpad.
