Air 820-00165 water damage no ppbus
yair37
water damage (cleaned) no PPBUS_G3H.
PPBUS_G3H 0V sometimes 0.7V
PP3V42_G3H 1.8V
PPDCIN_G3H_ISOL 16.7V
changed:
u5110
u7090
u7100
and reball u5000
Post diode mode to ground at L7130 and L7095.
Check U7090 area for corrosion; pay atention to R7095/96.
yair37
U7090 :
1-0.7
2-1.8
3-1.5
4-1.8
6-2.6
8-2.7
U7100:
1-15.6
2-16.4
3-4.4
9-0
12-1.8
13-0
14-1.8
15-0
17-0.4
19-5.1
20-5.1
27-16.3
Post diode mode to ground at C7092.
If short, remove the caps one by one amd test each time.
If still short, change U7090.
BTW, at least one of R/D7005 is burnt...
yair37
C7092 diode mode - 328
R7005 nothing , no read
D7005 - leg1-135 leg2 - no read leg3 - 334
i was replace r/d7005 but the same..:/
yair37
o.k fan work with just charger, but its not charge the battery the charging symbol apper just for 1 secound, there is green and orange light, and its work just with charger..
yair37
update:
r7115/6 and c7115 didnt seat wall...after out the right i was charge but just to 50% , now its not charging and just green light.
i was replace the battery again and the IO and the same.
Exact PPBUS_G3H voltage (without battery)?
Check if SYS_DETECT_L is 0V.
Post voltage and diode mode to ground at SCL/SDA lines of battery bus.
Be sure ISL6259 is properly soldered.
yair37
ppbus_g3h with just battery is 7.4v with just charger is 8.6v
SYS_DETECT_L is 0v
SCL/SDA on u7100 is 3.4v
ISL6259 looking good
The bus looks good now.
There should be a problem with SMC, or battery.
You can change ISL6259 first, to discard it.
