Apple Macbook Pro / 5.09v 0.41a / U3100 Damaged / Board 820 - 01041 - 07 /
zeydullak
Hello,
We have a Apple Macbook pro that had a damaged U3100, we replaced it, the board is now using 5.09v and 0,41a. checking under our thermal camera we see the T2 chip warming up along with a few other elemnets.
What else could be causing the problem and what should we start by looking at first.
Regards,
Zeydulla,
All the ports have the same behavior?
Compare diode mode readings on LDO lines of all CD3215 chips.
Just in case, reflash U2890; make backup first.
zeydullak
All the ports have the same behavior ranging from .41-.43. I did regular diode mode testing.
U2890 is holding the ROM firmware? I can read it but I dont have another copy of it to reflash. Do you have one?
U3100
PP1v8_UPC_XA_LDOA --> 1.3
PP3V3_UPC_XA_LDO --> open
PP1V1_UPC_XA_LDO_BMC --> open
U3200
PP1V8_UPC_XB_LDOD --> 1.34
PP1V1_UPC_XB_LDO_BMC --> open
PP3V3_UPC_XB_LDO --> open
UB300
PP1V8_UPC_TA_LDOD --> 1.38
PP1V1_UPC_TA_LDO_BMC --> open
PP3V3_UPC_TA_LDO --> 1.71
UB400
PP1V8_UPC_TB_LDOD --> 1.3
PP1V1_UPC_TB_LDO_BMC --> open
PP3V3_UPC_TB_LDO --> open
zeydullak
U3100
PP1V8_UPC_XA_LDOD --> .4880
PP1V1_UPC_XA_LDO_BMC --> .5167
PP3V3_UPC_XA_LDO --> .5151
PP1V8_UPC_XA_LDOA --> .5262
U3200
PP1V8_UPC_XB_LDOD --> .4941
PP1V1_UPC_XB_LDO_BMC --> .5264
PP3V3_UPC_XB_LDO --> .5265
PP1V8_UPC_XB_LDOA --> .5340
UB300
PP1V8_UPC_TA_LDOD -->.4946
PP1V1_UPC_TA_LDO_BMC --> .5202
PP3V3_UPC_TA_LDO --> ,5179
PP1V8_UPC_TA_LDOA --> .4304
UB400
PP1V8_UPC_TB_LDOD --> .4965
PP1V1_UPC_TB_LDO_BMC -->.5250
PP3V3_UPC_TB_LDO --> .5150
PP1V8_UPC_TB_LDOA --> .5343
