Apple MacBook Pro A2141 / 820-01700 / Short on PCB
zeydullak
Hi Guys,
We have an Apple MacBook Pro A2141 that did not turn on. USB-C meter showed stuck at 5V could not switch to 20V. We opened the back cover and we saw very dusty PCB. Removed PCB and checked under the microscope for possible corrosion. parts near to power chips / USB-C - 4 of them, were dusty. We cleaned them and then used thermal camera to analyze the board to see if we can detect any shorted element on it. We found one shorted capacitor which got hot (C9588). Also we saw that U5620 has corrosions on legs(ISNS_PPBUS_MAIN_SSD0_P). We removed it, cleaned the area and put a working donor U5620 chip from the working PCB. We also removed U9580 to check the legs but everything was ok on this chip mechanically.
We powered the mainboard without connecting it to battery. The volt switched from 5V to 20V and stayed at 0.05amps. We put the board back to computer and the computer started to use amps, we believe it was charging and amps went to from 0.05 to 2.5-2.7. After charging finished, we came back the next day we see it 5V and is not charging. Pressing power button and voltage goes to 20v and charging starts. We do not hear any chip and we do not feel any warmness on CPU side. While checking L chips around the CPU such as L7420, L7211 we do not have voltage. Upon checking for PP3V3_G3H, we do not see any power/votlage as well.
I need your help in this situation to move forward and to troubleshoot the issue. Please advise what to check. Thank you. See attachments as well.
Post diode mode to ground readings at L9080/580.
Any SSD voltage appears?
Also check the G3S voltages.
Is the machine recognized in DFU?
You can try revive; go for restore, if no data needed.
zeydullak
Diode mode testing results:
L9080-GND - 0.43V
L9580-GND - 0.411V
SSD0
U9100/U9400 - PP1V8_SSD0 -> 1.8v exist
U9100/U9400 - PP2V5_NAND_SSD0 -> 2.5v exist
U9100/U9400 - PP0V9_SSD0 -> 0.9v exist
SSD1
U8600 --> PP1V8_SSD0 -> 1.8v exist
U8600 --> PP2V5_NAND_SSD0 -> 2.5v exist
U8600 --> PP0V9_SSD0 -> 0.9v exist
Some power lines. Let me know if any other power line need, I can check it. Not quiet experienced.
PP3V3_G3SSW_SNS - missing power
5VG3S_VFB1_RR - 5v exist
PPVCC_S0_CPU - missing power
P1V8G3S_EN - 1.8v exist
PP1V8_G3S - 1.8v exist
I2C_SNS_G3S_SCL - 1.8v exist
PPBUS_HS_3v3G3H_T --> 12.5V exist
P5V_3V3G3H_EN -> 3.3v exist
The readings look good.
"Is the machine recognized in DFU?
You can try revive; go for restore, if no data needed."
zeydullak
Thank you. I connected the board directly to Mac Mini over charger cable and opened Apple Configurator 2, it did not detect it in DFU mode. No activity on Apple Configurator 2 at all.
I have a few questions.
When connected to charging cable, i do not feel any warmness on GPU and CPU. Also checked elements around GPU and CPU, power is missing such as: Is this normal?
PCVDDCIMEM_GPU_R - missing power
PP0V85_MEMCI_S0_GPU - missing power
Mainboard standalone means without connecting it to MacBook itself, should it be detect in DFU mode in Apple Configurator 2? Should we do something to make it go to DFU mode?
zeydullak
according my experience, if the board is in DFU mode, when you connect it to another Mac with apple configuration2 , it detects and shows it on the screen. Also the GPU and CPU area should be getting warm I think. Can you confirm this?
But when we connect, it does not detect it in DFU mode. Should we force to DFU mode? Thank you.
This machine REQUIRES 96, or 140W charger!
DFU mode doesn't need CPU to run.
Force it in DFU, if no other way.
