Apple MacBook Pro / Board 820-01700 short on ppbus_g3h
Roshon
i removed f7000 and f7001 the short on ppbus_g3h
L9080/580. no short
L7330 = 0.006
L7231 = 0.002
LA950 = 0.013
LA870 = 0.012
Check resistance between PPBUS_G3H and L7211-31.
Do you get 0.002?
Possibly one of U7210-30 is burnt.
Did you check resistance to ground at UA710-40 too?
Roshon
resistance between PPBUS_G3H and L7211 =0.001
L7231 = 0.001
BOTH U7210 AND U7230 HAVE ALL THE SAME READING ON ALL PINS SOME HAVE 0.003 AND OTHERS MUCH HIGHER
IS UA710 UNDER HEATSINK IF SO HOW TO REMOVE
Looks like you have one of U7210-30 burnt.
Lift one side L7211-31, to detect which chip is the culprit.
Roshon
L7231 PIN 2 PPVCC= 0.008
PIN 1 CPUCORE 1.895 AND GOES UP
L7211 PIN 2 PPVCC =0.009
PIN 1 CPUCORE 1.786 AND GOES UP
Roshon
when i lift L7231 the short to ppbus_g3h goes away BUT PIN 2 PPVCC_CPU_PH3 IS SHORT TO GROUND PIN 1 CPUCORE_SW3 IS NOT
