This is an extremely newbie question but I think it's important to ask: I'm swapping connectors between two logic boards and I don't want to damage either one in the process. What is the best way to go about it?
Should I use a board heater, add solder to pins, and then use hot air? Should I put kapton tape on the plastic?
Should I use a fine point soldering iron and tweezers to try to lift each corner of the connector individually?
Thank you for reading! I attached a photo of the connector for reference.
