Camera controller over-heat (no chime)
Hello,
Today I am on an A1466 model 820-00165 motherboard.
All voltage and resistance measurements look good.
I noticed C4002 and C4003 ripped off, so I replaced.
The fan is running but the card does not read USB, no LCD backlight.
With thermal camera I noticed U3900 heats abnormally 46 ° C
On a 35 ° C functional card
PP1V35_CAM is 1.35V
No other physical damage except these 2 torn components.
What do you recommend ?
Thanks in advance.
Any history fault available?
Who and how ripped off the components; maybe more damage caused on the board.
PLT_RESET_L comes high?
Try known good working BIOS.
I am only repairing the board, in general they are poorly stored and have components torn off. ?‍♂️
This is very normal on the cards I make...
Indeed PLT_RESET_L is not present (0V)
BIOS replacement does not change. The problem persists
PIN 7 = 3.17 V
PIN 3 = 0.17V
I had bad resistance on
SYS_PWROK_R
so I replaced U1950 and R1962
Now i get
PIN 7 = 3.4 V
PIN 3 = 3.4V
PLT_RESET_L = 3.33V
But still The fan is running but the board does not read USB, no LCD backlight.
Now I have replaced U6100 3 times, I even rechecked afterwards, all BIOS works on another identical board (1.8ghz 8gb)
The voltages and the diode resistors are also good when I compare with the functional board.
I noticed Q1920 with the oxidized and bad pin 1, I replaced the component and did the retrofit.
Do you have any advice on resistance checked?
