Converting 0005 to 9000 on 2915 boards
G.Beard
Hi.
I still have a bunch of 6490M chips left. I'm thinking it may be possible to convert the 2915 boards by:
Flash BIOS
Swap GPU
Swap VRAM
Change strapping resistors
Would that work?
Just don't. Save the chips for the board that need them as 9000 chips are nowhere to be found either.
All 512MB 0005 boards you can just slap a 9000 on there and it should work. On 1GB board you will need to change the VRAM chips so fuck that.
MDY
512MB hynix I put 9000 and works.
512MB Samsung I put 9000 and white screen. No apple. Later I put 0005 and works.
MDY
9000 is not compatible with samsung 512MB?
R8610 and R8611 are present.
MDY
I want to do it as I have just now a board with 512MB Samsung I put 9000 and white screen. Is there something that I can change and get it work? Any idea?
I have no idea. Compare strapping resistors between 9000 and 005 boards. R8613 and friends. I think 0809000 is only properly supported in the early 2011 BIOS so you can only downgrade early 2011 models.
