Dim screen only after login after replacing with new display assembly 2019 Macbook 820-01598-A
joshAU
Hi.
I replaced a cracked display assembly in a customers Macbook Pro A2159 (13", 2019).
On starting, the Apple logo, and the login screen, appears fine, however, once you input the password and actually login, the screen dims.
The brightness control slider on the keyboard is responsive, but it makes no change to the brightness.
The desktop is still visible, but a lot darker than normal, but isn't completely without backlight, as you can still see it OK.
I've tried resetting the SMC/PRAM, to no avail.
I've tried turning off automatic brightness control under System Preferences---Display, with no change.
I've tried with two new aftermarket display assemblies with the same result.
The unit displays fine on an external monitor.
Any help greatly appreciated.
Disconnect webcam and try again.
There could be an issue with ALS sensor, which is working only once macOS is booted.
joshAU
Hi again 2informaticos.
Thanks for your help, once again.
The webcam data lines seem to be integrated into the EDP cable that connects to J8500.
I don't think there's a way to disconnect the webcam...short of opening the panel, is there?
joshAU
AH, OK, Thanks for that. I'm not very familiar with this model
I disconnected the webcam side of things... but still no change unfortunately.
The screen looks perfect with Apple logo, and at the login screen, until I input the password, then it goes very dim.
However, a correction - the brightness slider bar does actually respond, and it does have some slight effect on the screen brightness- going from fully off to about 1/4 of the normal brightness.
I just cannot get it brighter than that, once logged in.
That is both with the webcam connector connected or disconnected.
If I select Restart, or shutdown, the screen will remain dim, i.e. the Apple logo and login screen will be dim, unless I reset the PRAM first.
I also tried with another installation of OSX Big Sur, and booting from a Catalina USB installer, all behave similarly.
One thing I did notice, is that immediately prior to the screen dimming, the actual colours change for 1/2 a second, like some sort of graphic artificing, then the screen dims.
For example, the White Apple logo on the black background will flicker to a white logo with a red background, then the screen will dim, and the colour will return to normal....
I've attached a 10 second video of the issue.
The glitch occurs 6 seconds in.
(For some reason .MOV files cannot be uploaded here directly, so I had to put it in a zip file).
It makes me suspect perhaps an issue with the GPU....
joshAU
Hi piernov and 2informaticos.
Sorry for the delay.
I did try it with two brand new aftermarket screens, however both were from the same supplier.
We buy quite a lot different mac screens from that supplier, and rarely have issues, but I think this is the first time we've bought that particular model.
T2 machines give lot of problems with cheap chinese LCD assemblies.
They usually do not mount a proper ALS circuit.
