EZP2019 BIOS Flashing
grmacs
Wondering if there are any others out there struggling with this model. It rarely detects the chip and I end up spending a lot of time trying to figure out what chip, so I'm rarely ever able to just plug it into the j-connector and reprogram, I end up pulling the board if the chip is on bottom. This would be ok as I can log the chip types per board numbers but 50% of the time I'm unable to find a compatible chip configuration that will successfully read the chip! Seems as though a lot of chips on Macs are not setup in EZP2019 software.
Am I missing something with this? Is there a way to get updates? Or manually configure?
Probably bad connections.
If programmer really doesn't recognize the chip, find its capacity and voltage with Google.
Then choose similar chip from its list and try to read it.
