[FUBAR] LB 820-2879 B no green or orange light (needs SMC)
Mac-N-Sauce
So I have PP3V42_G3H on the one wire circuit coming through pin 1 of C6908 and other areas. How do I know if i have a bad U6901 vs a bad via?
larossmann
I uploaded a few pictures from a diagram to try and make this make more sense. This was hastily put together at 2 AM in MS paint while half asleep, so try not to make fun too badly..
edit, pievce of shit cut out half of my pdf. let me fix this
larossmann
I uploaded a few pictures from a diagram to try and make this more obvious. This was hastily put together at 2 AM in MS paint, so try not to make fun too badly..
larossmann
and here's the rest
Mac-N-Sauce
Ok, I have 3.9v CHGR_ACIN BUT AM NOT GETTING PIN 14 CHGR_ACOK. Had some bad capacitors C7020,c7021,c7022 also bad q7085. replaced all of them. Still have no 3.3v on pin 14 of U7000. Looks like other voltages are correct. could it be a blown U7000?
Have not replaced it yet.
Mac-N-Sauce
By the way, thank you so much for describing the path. that helps a lot. I was working on the Q7085 side not the other one. I couldn't get voltage through the Q7085 so I replaced it, then I was able to track voltage down to resistors, to the U7000 pin 27/28 CHGR_CSI_P, CHGR_CSI_N, CHGR_AGATE
PIN 1 = 14.8V, PIN 2 = 16.65V, PIN 26,27,28 15.95V
​I still don't have the right voltage on pin 14
Mac-N-Sauce
No Title
Appears to be soda on the bottom of board. Other side had very little if any.
larossmann
the chip has more load on it than anything else since PPBUS_G3H powers the entire machine, and it also has to deal with knockoff chargers and ripple on PP3V42_G3H as well as its own issues when there's water.
