garbled image on 3332 board after U8900 fix
This board came in for the all-too-common U8900 issue: upon arrival the machine worked fine, but would crash once the board switched from Integrated to Dedicated GPU (the typical MUX issue).
I have redone the solder on U8900, but after reassembly, the screen is showing distorted/garbled image. I have tested with another compatible screen, but the issue is the same there.
See my attached image for what i mean by distorted/garbled image.
Any ideas what may cause this issue? I have triple-checked the soldering on U8900 and its surrounding components: all looks flawless.
Any ideas where to start chasin this issue?
i should also mention that i have swapped U8900 for another chip from a donor; but unfortunately, the issue remains the same.
I have inspected the board for any knocked off components but no dice..
Image problem may be caused by GPU, or VRAM.
Maybe a BGA chip from graphics area reacted to hot air.
