[help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
phantom
i don't know the history of this motherboard...i've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
should i reball it? should i change it?
phantom
ok now i have
PPBUS_G3H=8.18
3V42_G3H=3.42
3V3_S5 3,3
no voltage for PP3V3_SUS (no shorts
on u8020 i have 0v on P3V3SUS_EN no shorts
0v on R1464 no shorts
Maybe bad SMC, or solders.
Did you get it from same model board?
Check SMC_ADAPTER_EN, PM_BATLOW_L, PCH_DSWVRMEN, PM_DSW_PWRGD and the 4 PCH's RTC signals.
phantom
i mean bought new, not from donor board
SMC_ADAPTER_EN, 0v
PM_BATLOW_L, 3,3
PCH_DSWVRMEN, 0v
PM_DSW_PWRGD 0,9v
Not normal.
Check first the capacitors connected there.
If still short, remove u1900 and check again.
Lastly bad PCH...
SMC must be programmed with corresponding firmware for your board!!!
