Hi guys i have an 820-00840 that not boot... (stuck at 5v)
here there is the history of previous techician (i can't say if it is 100% true)
macbook dead
found a short with thermal camera on c3000
caps removed (not replaced)
tried to charge -> smoke
found u3100 burnt
changed, no luck
changed u3200 no luck
rechanged u3200 with the original one. No luck
now i have this laptop.
i have changed both usb-c chip from a IDENTICAL donor board and C3000
FINALLY 20V! BUT NO BOOT
Using Thermal camera i have u7800 super hot
uploadnow.io
I have checked for shorts around and under u7800 with no luck
I have pp3v3 ldo 3v
I have ppbus pmic 13v
I have pp1v25_ref 1,3v
But pp5v ldo stuck at 2,7v This Line is not shorted
replaced u7800 (from donor board)
Now i have po5vldo… u7800 is not super hot anymore…(but hot together with u7100)
Now is super hot u3900 and a little bit cpu…
This is the amp meter
https://uploadnow.io/f/nJDYmsx
Changed u3900 still the same
I have Nothing on display, no caps lock no fan spinning
macbook dead
found u3100 burnt
changed, no luck
Scarica
Una cartella/file condivisa è disponibile per il download e lo streaming con UploadNow a questo link
I have pp3v3 ldo 3v
