[help]Imac 21,5 EMC 2428 Dead
Post U7700 basic voltages: 17, 18, 5, 4, 24, 12.
i've dismantled the motherboard for the first time, changed u7700 with a brand new..now i have this voltage
12, 5, 5, 5 3,3 3,9
on l7750 i have 0v on both sides
0.144 mv in diode mode
If all solders are good for sure, then check all surrounding components from 5V side.
Do you still get 3.3V at L7710?
what do you mean with "5v side" side of what? u7700?
u7700 is solderet perfectly...
i confirm i have 3,3 on l7710
5V power supply is enabled (pin 24).
"0.144 mv in diode mode"
What this means?
I repeated many times on the forum, do not post "V" (nor mV) after diode mode reading.
Post the resistance to ground in ohm scale.
How not short at pin 1, if is connected on the same line?
Broken trace?
Remove R6970 and check again in diode mode.
U6900 and U9120 are the next suspects.
i've found the problem of the short, i've removed it resoldering u7700 again.but still no voltage on l7750
