[help]Macbook Air 820-3437 Dead
ok now with another u7501 i have pp3v3_s5
0v on PM_DSW_PWRGD
SMC_S5_PWRGD_VIN 3,3v
S5_PWRGD not present
0v on PP3V3_SUS
0,3v on PM_PWRBTN_L
PM_PWRBTN_L is 0,3v but it should go to 0,3v when triggered!
r1405 is 1k, i have 3,3v on the other side...so i don't understand
SMC_ONOFF_L. 3,4v
SMC_RESET_L 3,2v
U7501 controls it; as already explained before.
Bad SMC can pulled it down, but is not usual.
Is more easy to isolate U7501, than SMC; on S5_PWRGD line.
Isolating the pin will give you an idea if the problem comes from U7501, or not.
There is still a chance to have bad SMC; however less probable.
i will go crazy...i've soldered another smc..now i have 3,2 on the other side of r8141 but no power led on magsafe... i have even pwrbtn_l 3,4V!!!!!
ppbus_g3h is 8,16, PP3V3_S5_SMC_VDDA 3,4 sysonewire 3v (should be 3,4?!) PP1V2_S5_SMC_VDD 0,9 v!?!?!?!? should be 1,2? (line is not shorted)
No way.
You can get it from 00165; probably from other MacBook Pro 2013 or newer.
In such case (not same donor model), will need to flash the correct firmware into SMC.
You can find SMCTools on Internet...
Your board doesn't work now.
If that is caused by bad SMC, you can flash it AFTER changed it; if is the culprit.
