HP AIO - 24-b223w - Won't power on, can't track issue.
Jameswis
I'[m working on an HP AIO.
board number DAON83MB6G0 rev3. I have the baordview and schematics.
The board won't turn on. At the power button, i don't have 5v.
The schematics shows bot S0-S5 states and A G3 State.. The only power rails i have with the power adapter hooked up, are those listed under G3... So I'm no sure where to look next. Can someone please point me in the right direction?
Do you get 3V at PWRBTN#?
If not, disconnect CN19 and check again; you can use SW1 pads instead.
If sltill low, be sure R570 is good.
Jameswis
I will check if I have 3v at power button, but Please answer me this?
When i look at the schematic / boardview at the power button connector, they only show 5v_S5 PWR.. I don't see any of the 4 pins labeled as 3v.. So should i be looking for 5v or 3v? (Im not trying to be a wiseass, I'm just trying to understand in a way that I can learn it.)
Thanks.
I'll check on this when i get home..
Power button is something like SW1; do you see any 5V going to SW1 pads?
The pull-up resistor for PWRBTN# is R570, to +3V_ALW...
Jameswis
Well I just did it. In poking around i slipped and shorted 2pins on an 8pin chip (PU11), Which I think is a voltage converter, and let the smoke out of it. I just ordered another, so hopefully i can get it swapped and keep testing. I guess I'll be back in a few days... lol
Jameswis
I've got the new chip soldered in, and I'm back to testing.
On the board view, Looking at SW1 It has 4 pads. 2 are ground and 2 are PWRBTN#...
Both PWRBTN# pads have 3.29v on them..
The actual connector with the ribbon cable for the power button is CN19 and has 4pins..
Pin1 = Ground,
Pin2= Pwr on LED# (This measures 3.29v but bounces to 0v and back to 3.29v over and over about every second)
Pin3= PWRBTN# - 0.0v
Pin4= +5v S5 PWR 0.0v
So i have No 5v at the power button connector.
R570 has 3.3v
I don't really understand why do you still expect 5V at PWRBTN#; it is pulled up to +3V_ALW!!!
Find the broken point for PWRBTN# line.
You can run a wire from SW1 to CN19...
Jameswis
I don't expect to find 5v at PWRBTN# However I would think I would find 5v on +5v_S5PWR correct? (IDK.. If I knew i wouldn't have paid for the help on this forum.. lol)
I don't think running a wire will help because the path from SW1 to CN19 is fine.
Correct me if i'm wrong, but on SW1 i should be able to use a momentary switch from the 3.3 to Grn and have the system turn on/off? I've tried with a jumper wire there to a ground pad and it won't try to turn on at all.
You've said to have 3.3V at SW1 (PWRBTN# pads), but not on pin 3 of CB19 (0V on same PWRBTN# line).
Can you then explain how the PWRBTN# line is not broken???
+5V_S5 power rail requires S5_ON, which appears AFTER power button is pressed.
"I've tried with a jumper wire there to a ground pad and it won't try to turn on at all."
Did you disconnect CN19?
Be sure to have 3V at SW1, when run that wire.
KBC's pin 107, must detect 3-0-3V signal drop when PWRBTN# is triggered.
Jameswis
I follow what you're saying now, and I understand the confusion. I got a little ahead of myself when I was writing out the numbers on CN19. Let me do this again..
Pin
1 - Ground - 0.0v
2 - Pwr ON LED - Bounching 0-3.29v
3 - PWRBTN# - 3.29v
4- +5V_S5 - 0.0v
So i have 3.3 on PWRBTN# at both SW1 and CN19.
Jameswis
ok... I'm sorry for this, but we need to start over. I broke something else when troubleshooting and fixed that issue, and then created another. I replaced the part i thought was heating up, but apparently the part heating was on the opposite side of the board and i didn't think to flip it once i found something heating that much...
So heres the situation now..
No more power LED at power port. No more 3v at SW1.
on the bottom of the board i have a chip I can't find on digikey or even google (with whats actually written on the chip) and it is written as 3G=4H M3X....
In the schematic it shows this chip as PU21 RT6575AGQW... Even with this RT number I can't find a data sheet to figure out what it does to know how to test it. This chip gets sooooo hot it will burn my fingers when plugged in for only a few seconds. This didn't happen before i shorted whatever I shorted in tested before..
So i need some direction on where to test now before just replacing a chip i can't find...
And I'm also confused about something, so I'm going to ask (Please don't bite my head off for it)... Something I'm not understanding is the different Voltage lines on the schematic.. Around this chip I'm seeing stuff like i've written below and I'd like to know what it means:
3v_Phase
3v_Boot (I can kinda guess this one)
3v_UG
3v_FB
And finally the one thats made me give up is VIN_3V... On which i have 19v... IDK if this should be 3v or 19v.... Or does this mean its the +VIN feed for the +3v circuit?
Sorry.. I know this was long, and there's a lot here, but I'm having a bad week and this didn't help things today...
Thanks
If you still get correct +VIN (19V), you are lucky; maybe no problems on +3V_AUX and +5V_S5.
KBC is probably fried and you have a short on +3V_ALW rail.
Remove PR324, to confirm that; may need to cut off the trace, if no physical resistor soldered on the board.
"3V" in that signal names denotes their relation with 3V power supply; nothing more about their voltage level.
IC datasheet clarify what means each signal.
A small bonus:
3F= RT6575BGQW
3G= RT6575AGQW
3J= RT6585AGQW
3H= RT6585BGQW
5Y= RT6575CGQW
5X= RT6575DGQW
Jameswis
WOW!!! Thanks for all the extra info there. That really helped a lot. No resistor on PR324 so cutting the trace look like my option...
Before I do that I just want to be very clear on evertything so i don't screw more up.. lol
So I'm looking for a short to ground on +3v_ALW once PR324 is removed correct? (well Trace cut)
And is there any specific location i should probe +3_ALW after the cut?
I feel dumb for asking this but What does KBC stand for? Is it Keyboard Controller? Or is it another way of saying SUPER IO Chip?
Thanks,
And I'm sorry for being such a PITA... I'm taking a logic board repair class in about 3 weeks and I'm trying to pickup as much as I can now.. Hopefully asking you a lot now, will help make it easier for me in the class, and if goes well, I won't need so much hand holding after... lol
Jameswis
I went ahead and cut the trace. I verified to continuity through the cut. On the trace side, its a dead short to ground. On the side of PU21 pin3 I don't get short to ground.
Jameswis
Dead on the money. U34 gets warm / hot when I inject 1.1v @ 0.75 amps. Any less and the CC protection would kick on and drop the voltage causing the chip not to heat up.
This would point to the SuperIO, but I wonder if that chip was bad all along, or I blew it when shorting the other connector in testing? I've been looking for a reason to buy a Super IP Programmer.. Maybe now is the time. :)
You cannot set V and A at same time, when inject voltage.
Learning more about Ohm Law can help you.
If you set amp limit of lab power supply at max, I'm sure you can inject 2V and get KBC hotter.
However, no need to inject more, if already detected it as the culprit.
Need to change KBC first, not always need to flash it.
Schematic says something about auto load code in this case.
The KBC got fried because of some short you've done on the board...
