iMAC 21 MID 2011
andrespi
Hello, I installed the solid state hard drive but there are problems with the fan, I read in the forum a solution for imac 27 "taking the 11 pin sata connector to ground, I wanted to ask if the same applies to the imac 21", and any recommendations and if you know because it works well thank you
it works on 21inch 2011 models as well.. just solder pin 11 to ground (i usually take apart the SSD, and solder pin 11 to an adjacent ground-pin with some solder-blob, and close the SSD up again) and you should be good to go
