iMac 27" 2011 - no backlight - turns on for 1 second on boot
quasimodo
Hey,
any idea for this problem?
iMac 27" 2011 Backlight not working.
Graphics good, iMac boots, externally fully functional.
The backlight turn on for 1 second when i press the power button - then shuts off.
LED driver board is replaced. Same problem.
Any ideas?
Can you post 820-xxxx code of your board?
Any history fault available?
Confirm if image is present, only missing backlight.
quasimodo
dont know the 820 code..
27" 2011
machine of a strong smoker...
image is present - only backlight is missing. backlight turns on for 1 second on boot, then shuts off..
It should be 820-2828, but you should post correct code when open new thread!
Check VIDEO_ON and BL_EN, with LCD connected.
