imac 820-2901-A not communicating with video card
protocold
Chime when power on. The diagnostic leds only show 1 and 2, Led 3 is missing. The video card is tested good on another machine.
I ONLY look on the schematic when try to help.
You should be able to locate on the same schematic the LEDs which stay on; boardview can help you at this moment.
If the MXM card is good, probably you have some failure on the power on sequence.
So tell us which voltages appear on your board.
Which is stable and which pulses only, if is the case.
