daxxone
Power on cycles 3 times befor giving 7 beeps error.
sualaptop365.edu.vn_15or17 LA-B753P.pdf is the schematic file name I found for this board. No boardview available but chips are labeled on the board.
UA4 gets warm (audio amp, starts getting warm when beeps start, not crazy hot, just warm). As does PL503, PL502, PL501 (gets very hot, but the CPU isn't taking any of the power). 1.703v when system is on, no heat at the CPU? The CPU is BGA, so is this an issue with the BGA or am I having an issue with voltage not getting stable fast enough to start?
No signs of spill damage, no burns. System looks like it was low hours of use.
Not sure where else to check.
