Hi all.
Liquid damaged 820-00165-A
Minor corrosion on top side of board around U6100 - U1900 & U7701.
On the bottom, only a tiny bit near Q7155
Cleaned affected areas.
Get green then amber LED on magsafe2 adapter.
Tested with spare known good adapter
No fan spin.
I've tried to manually start it via shorting R5115/R5116, even though should turn on without battery when AC is connected.
It gets vaguely warm in two areas, around U2800 and around L6560, but not warm enough to isolate which component is causing it, or even which side of the board it is coming from.
No heat from CPU.
ALL_SYS_PWRGD is 1.2V
PM_SLP_S4_L = 3.32v
PP1V8_S3, PP5V_S3, PP1V2_S3, PP1V05_S0, PP5V_S0, PP3V3_S0, PP1V5_S0 all measure correct voltages.
PPBUS_G3H = 8.56V
PPVRTC_G3H = 3.3V
RTC_RESET_L = 3.3V
PCH_SRTCRST_L = 3.3V
PCH_INTVRMEN_L = 3.3V
PCH_DSWVRMEN_L = 3.3V
PP3V3_S5 = 3.3V
PM_DSW_PWRGD = 3.3V
PP3V3_SUS = 3.3V
PM_BATLOW_L = 3.3V
PM_RSMRST_L = 3.3V
PM_PWRBTN_L = 3.3V
Any help greatly appreciated.
No fan spin.
No heat from CPU.
PM_SLP_S4_L = 3.32v
PPBUS_G3H = 8.56V
PPVRTC_G3H = 3.3V
RTC_RESET_L = 3.3V
PP3V3_S5 = 3.3V
PM_DSW_PWRGD = 3.3V
PP3V3_SUS = 3.3V
PM_BATLOW_L = 3.3V
PM_RSMRST_L = 3.3V
PM_PWRBTN_L = 3.3V
