Liquid damage from water. Corrosion around UD560 connections under that chip are now good. DCIN voltage is 5.16V on both ports and zero amps drawing. Checking the CD3217's I'm getting the LDO's on the chip related to the powered port but the readings on the opposite chip are pulsing and erratic. This happens regardless of which port is being used... stable voltage on the connected port and unstable voltage on the unconnected port/CD3217. I found this rather odd but haven't worked much on boards with CD3217's. Checked for shorts on big coils and all at least appear to be good at .100 or higher.
