nicerepairs
QUOTE (I lost access to my other account, that's why I quote this here, sorry) :
"I have this really weird problem.
Screen is 90% black (from bottom to top, only top bar is visible). I changed it with another from a donor but there was some dimmed and almost black lines on top. I tested his original display on another Macbook and it works perfectly fine, so I thought maybe it was a LCD cable issue. I assembled it back but screen doesn't turn on at all. I tried with the replacement one (with the dimmed spots) and it doesn't turn either.
Currently it doesn't light up with both of the displays. It has picture on external monitor, so I know it's booting.
Any idea what to look for?"
YOUR ADVICE:
Do you get 3V3/5V_S0SW_LCD?
Check also DP_INT_HPD.
Diode mode to ground at pins 1 & 3 of J8500?
OUR RESULT ON THE TEST:
3V3/5V_S0SW_LCD is NOT present.
DP_INT_HPD is low level 0V.
Pin 1 is NOT present. Pin 3 is present.
Additional measurements we did:
VDD Pin 1 is present. Pin 2 EDP_Panel_PWR_EN is NOT present - 0V.
I've done SMC Reset and NVRAM reset.
Also update, it now doesn't even boot on external monitor... Please help. Really important Macbook.
Thanks!
YOUR ADVICE:
Thanks!
